The migration from AIMMS PRO 1.0.x is facilitated by the AIMMS PRO Configurator.
Migration section In order to perform a successful migration from AIMMS PRO 1.0.x to AIMMS PRO 2.0, you need to make sure that the following criteria are met:
The AIMMS PRO configurator will check these criteria for you and will show an error message if they are not met. Otherwise, you can start the data migration using the corresponding button on the screen.
