Case Sensitivity
AIMMS PRO 2.0 is case insensitive, meaning that the values ‘test’ and ‘Test’ are treated as the same value by AIMMS PRO 2.0. Please note that this was not yet the case with AIMMS PRO 1.0. This case insensitivity is valid for all input parameters: user names, environment names, group names, AIMMS application names and versions, the strings in the execution and priority rules structures, etc. The first time any of these parameters is created, the case is saved, but after that, any attempt to create another parameter with the same name, but with a different case will not succeed (failing or returning the already existing name, depending on the situation).
