As part of every AIMMS release, so-called AIMMS PRO Server packages (for Windows and Linux) will be made available. Through the AIMMS PRO portal, all users with global administrative privileges and users who are member of the AIMMSPublishers group can publish AIMMS PRO Server packages to AIMMS PRO. You can use published AIMMS PRO Server packages to deploy AIMMS applications that are developed and tested using the corresponding AIMMS developer releases. Each AIMMS PRO Server package contains:
All published AIMMS versions are available for deployment of end-user applications to all users from all environments.
Please note that if your PRO server is running on Linux then you need to publish linux AIMMS versions (i.e. AimmsPROPackage- which are available with each AIMMS release starting from AIMMS 4.14.
On the AIMMS Versions section of the PRO Portal, you can also delete AIMMS PRO Server packages that you don’t need anymore. In case the version that you want to delete it still in use by one or more apps, an error message will tell you so, and the version is not deleted.
